- Wenatchee, WA
- 4x4-Mega
- BigRock 4x4
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Outcast 4s
- Typhon 3s
- Voltage
Greetings all,
Just sharing my Typhon 3s build I've been working on for a couple months. This project started out as just a normal Typhon 3s build made 90% from extra Jenny's spares in my inventory. At first I planned to make it a truggy with some Badlands 2.8s but later decided to make it a dedicated speed runner vehicle because I don't have any cars like that yet. When I started I had a reasonable 4s capable system (Hex10 esc + 2800kv 4s motor) but decided to push the envelope and try to stuff a 6s system in it.
Anyways here's the build sheet thus far:
Currently I've been testing on a 21T pinion until I get the hang of things and then will be bumping up to a 26T pinion assuming no major design failures/breakages, but so far so good. Definitely requires a lot more skill to control than I expected.
- BLX 185 (3-6s) esc + Arrma 6s (2050kv, 4074 size) motor w/ Hot Racing adjustable motor mount and HobbyStar dual fan heatsink
- 4s metal spur/slipper
- DS3225 servo
- 6s Shocks shortened and made more stiff for speed runs
- Mojave springs in front, Kraton 6s springs in rear, shafts shortened 10mm front/8mm rear
- GRP 1/8 scale (98mm) wheels/tires
- Hot Racing 17mm w/+10mm offset hex adapters
- RPM Typhon arms
- Traxxas XO-1 tie rods
- Stock typhon tie rods were hard to find at the time so I rolled the dice on the XO-1 rod set on Jennys. These seem to be a pretty good alternative, just need some washers/spacers in a couple of places but other than that the length is good with a little adjustment
- Typhon 6s wing
- 50k front/30k rear diff oils
- Full rubber sealed bearings throughout
- Lots of custom designed 3D printed solutions
- TPU wing mount, nylon front speed bumper/wing, PETG custom receiver box lid, PETG esc mounting plate, TPU dual fan cover, TPU SkyRC GPS speed meter case/front body post mount, and a few other odds and ends
