- Vorteks
Ok just going to get a fan. And fan mounts.That motor already has cooling fins so as others have mentioned you should just use a fan. I've had good experiences with the Rocket fans. Worth noting though unless you gear that thing to hell and back a 4268 motor in a vorteks is gonna run very cool. I hope you've upgraded the ESC as well because the stock ESC is not going to like that large of a motor.
I would highly encourage you to go to an 8BL150 for that motor. 10BL120 is going to run hot at best and burn out entirely at worst with that motor.Ok just going to get a fan. And fan mounts.
Yes upgrading the esc to a QUICRUN WP 10BL120 G2 ESC (2-4S)
Thanks.
The standard 10BL120 is inadequate but they said the WP 10BL120 G2 ESC (2-4S) is 4s rated and was recommended on their website with this motor.I would highly encourage you to go to an 8BL150 for that motor. 10BL120 is going to run hot at best and burn out entirely at worst with that motor.
Any finned motor should not be used with a heat sink or thermal paste. They should simply have fan mounts and a fan(s) blowing over the already machined ribs, as they are the heat-sink. Only smooth can motors benefit from a tight fitting heat sink fan mount, with or without thermal paste.If using a heatsink be sure to install it with a thermal pad or thermal grease. Otherwise the heatsink will be useless...
Hobbywing recommends a Max8 ESC for that specific motor, which I believe is 160A.The standard 10BL120 is inadequate but they said the WP 10BL120 G2 ESC (2-4S) is 4s rated and was recommended on their website with this motor.
That's why I got it.
He is right though that the 10BL120 has specs for 4s to run 4268 under 2600kv. Hopefully it's the one under 2600kv cuz it will die otherwise. It might be okay honestly but it's gonna run hot.Hobbywing recommends a Max8 ESC for that specific motor, which I believe is 160A.
That 120A ESC is going to suffer for sure.
I will keep a close eye on temps.He is right though that the 10BL120 has specs for 4s to run 4268 under 2600kv. Hopefully it's the one under 2600kv cuz it will die otherwise. It might be okay honestly but it's gonna run hot.
Here's the spec sheet
That seems to be the what everyone is saying. Going that way.Any finned motor should not be used with a heat sink or thermal paste. They should simply have fan mounts and a fan(s) blowing over the already machined ribs, as they are the heat-sink. Only smooth can motors benefit from a tight fitting heat sink fan mount, with or without thermal paste.
Yes it is. Here's a comparison picture of old and new.Cool, good luck!
It is a serious motor for that car
How did this go? Did the 10BL120 handle it okay?Yes it is. Here's a comparison picture of old and new. View attachment 335092
Yes it sure did. Here is the installed setup. It's insane on 4s. Already blew the foam out of the stock tires running on ice.How did this go? Did the 10BL120 handle it okay?
