Nero tierod end
Found kind of a workaround if you can't get ahold of rod ends (because they're out of stock...) and want to run. You can use a complete revo pushrod as a replacement. Nearly the same length, have to use some shims on the rocker end as the balls aren't wide enough.
traxxas pn 5319
The rod ends are shorter than arrma, but the metal link is longer so it ends up close to the same length. They're not as beefy as arrma's 4mm vs 5mm but you can make them work..
I got some sent out under warranty. They cited some early model ones (Got mine first week they were out in US) as having a batch of weaker track rod ends (mine failed very early with no jumps or hitting anything hard, the plastic just went super floppy! If you really struggle to get some within a reasonable time frame and are in the US please PM me
Use some RPM rod ends
I replaced mine Tire rod and ends with traxxas part.#5319
Yes
Yes
Sorry guys yes heavy duty end from traxxas part numbers are 5348
Full aluminum pushrods for revo part number is 5139x
These are the ends if you just want those
Great info guy's, I think I'm going to try the 5348 tomorrow. I've been down a week and ready to have some fun.
What is the RPM part number?
I found the 5319's the other day and they worked, I ended up shimming the rocker end w/ a couple of washers as it was a little loose. Worked fine though.
I've only driven it a few times. I been driving in a new subdivision that only has dirt pads with small bumps for jumping. To be honest I don't really know what happened. I noticed it when I brought the car up to me. There wasn't a moment that I said "oh man something got to be broken after that". I've also been somewhat cautious how I've been driving since I'm new to the hobby and want to get the feel for the car.
I will also look at the Big Rock rod ends. Thanks for the input fellas.
H.D. on the B.R. and standard on the Nero.
Hey I broke my turnbuckle rod-ends on my first drive. Part number is the same as the other rod-ends.
So based on these threads I ordered some Traxxas 5348, but no way they fit. They are 3mm diameter instead of 5mm. Also, the original Arrma is 31mm length, whereas the Traxxas 5348 is only 22mm.
So, quest for rod-ends continues. Thinking Losi6539, or thunder tiger PD1921, any other suggestions?
The thunder tigers look identical to the team associated ones. I would get those.
