BoostedMedia
New Member
Hi guys,
First time posting here. Just picked up a new Vorteks a few days ago and immediately ran into issues with Low Voltage Cutoff triggering at Wide Open Throttle even with a fully charged battery.
There's been quite a bit of discussion online about this issue, with varying levels of success, however I discovered there's a new version of Firmware that was just released in December 2023 that now allows you to manually adjust the LVC trigger voltage. I set mine to 3.4V and the issue appears to be resolved.
The catch is you'll need to purchase the Spektrum Programmer V2 which isn't cheap.
Once you have the programmer, you'll need to update it to the latest firmware, then connect it to your ESC and update the firmware on that too, which will unlock the ability to adjust LVC.
Instructions and the download can be found here:
https://www.spektrumrc.com/product/smart-esc-programming-update-box-avian-and-firma/SPMXCA200.html
NOTE: Many people are having issues with the software freezing when trying to connect to the ESC. You need to extract the zip and rar files using a 3rd party extraction tool like 7Zip. If you use Windows inbuilt extractor the software will not work.
Its BS that you have to purchase an additional accessory to make the product work properly, and I hope ARRMA supplies all their distributors with a programmer so they can update their stock before selling.
Hope this helps!
Hope this helps!
