Timmyn71
Just picked this baby up today and after first setup it's rainy I'm pissed I want to run it
nope its only upper end quality for this its is it needed or do you want and the needed come from well known sources but thanks for the input well appreciatedCongrats! It's a fun one.
Whatever you do though, don't go on the scortched parts rc website.
Your wallet can thank me later.
putting the castle 1717 1560 in it and got a futabo 4pm if your going to do it i guess you need to do it right otherwise you will be doing it laterCongrats
Yeah your not shittin just got Thursday and at least got to smell rubberBuy and install scorched inner fenders before your first run. You won't believe the amount of rubber and rocks this thing gets inside itself. Also, I recommend maxing out the ride height if it's just a basher to try to save your front splitter from as much abuse as possible. Also, also, turn the timing down to 0, the Infraction gets it's motor temps high and timing down helps.
Edit: nvm about timing, I see your changing out the electronics.
