Hi guys ,
I am thinking to buy this car but I understand that is a model from 2022 , is it going to be a new model ?
*** is it a recommended car??
It is a very nice RC...has it's own place of all the 6S in my opinion.Hi guys ,
There’s very little difference between the Big Rock 6S and the Fireteam. That being said, it’s definitely not financially savvy to get a Big Rock and try to get a FireTeam body on there. The FT body and needed plastics would be close to $200, even with parts from JRC’s. (I’m currently doing the reverse, still ain’t cheap!)It is a very nice RC...has it's own place of all the 6S in my opinion.
Yes, if you have done your research and know what type of rig you are getting.
I have both fireteam and the new big rock 6s. Although the FT and BR6s are of course nearly identical, I enjoy the BR6s more.
Maybe the BR6s body just appeals to me. They drive similarly (both have mediocre tires). I dropped some backflips onto the FT and it rips now. Easy fix.
If you love the FT I’ll make you a screaming deal on mine. Just dm me. I need to sell it anyway. Happy to sell in whatever configuration you want (roller, stock, or highly upgraded electronics).
Buying used is how I hedge against the inevitable new model that always shows up right after I buy a particular truck. Doesn’t sting nearly as much when you are only in for half price or whatever.
Same! That's why I'm making my FT a Big Rock. The Big Rock body is legit, and these side steps are tough! I haven't weighed them yet, but the bodies feel close to the same weight...heavy. I fully intend on putting the 5th wheel hitch on the Big Rock to use though!I have both fireteam and the new big rock 6s. Although the FT and BR6s are of course nearly identical, I enjoy the BR6s more.
Thanks all for your response, I will chose another RC car , probably the new Kraton 6S EXB RTR v2Hi guys ,
That's not a bad place to be. The FireTeam is more geared towards ground bashing. The Outcast is geared towards stunts. The Kraton sits in the middle of those two. My personal preference is to have an Outcast and a FireTeam. The Kraton is good all-around, but it's not as good as either of those 2 models at what they do best. This is just my personal preference, but I play with my Outcast (8S) all day long. Doing wheelies down the street, flipping off of ramps, etc. My favorite RC of all time.Thanks all for your response, I will chose another RC car , probably the new Kraton 6S EXB RTR v2
Where are you located?
I love my FT. Especially during the 2022 Black Friday sale for a measly $400.00. Shipped free. It's not considered old by now by Arrma standards. Was released in very late 2021.Hi guys ,
It definitely has a bit of a quirk to it. It's a ground pounder for sure. And while it is extremely stable, it doesn't take much for it to flip end over end. Still a fun rig to drive though!I love my FT too, but that top shell is sooo heavy. It turtles when doing donuts, and flips in weird directions when landing from big jumps. I have no idea if the Big Rock is the same way. It’s basically just a FT with a new shell, and the shells feel about the same weight. TBD if it’s better. I just got the 3ft Freshpark ramp in, so I’ll find out soon enough!
I changed the hubs from the Limitless hubs to the Kraton hubs. It’s a good bit more stable without causing any issues with the bearings, like you see from spacers. I also went Treal. They were a good deal, and now I have triple bearings.It definitely has a bit of a quirk to it. It's a ground pounder for sure. And while it is extremely stable, it doesn't take much for it to flip end over end. Still a fun rig to drive though!
Curious what drawbacks you saw? I haven’t noticed any myself, but my use case may differ.I readjusted my roll center at the rear camber links, brought my droop down more, moved the Lipo tray rearward and mine is planted, adjusted my Fr and Rr sway bars better, set shock preload , and is very stable now. Doesn't nose dart anymore. No more traction rolling. Many just go to the wider K6 hubs. Get's costly IMHO. But also works for some. Merely widening the track width has some drawbacks. I noticed this when I tried wider CH 2 tires on my FT. I prefer the stocker FT tires TBH. No interest in running any other tire.
I just may throw it on my Cross weight scale again. Did that out the box in full running weight, but didn't consider it much. I never rechecked it after I moved the Lipo tray rearward, and removing the HB. Mine runs fine as she is right now. As good as it gets for my liking. With stock electrics I can pull wheelies on demand all day, if I want. Motor ESC Timing is all the way down. Default 22.75 degrees is way too much IMO. Running the Speed gear right now. Temps are under control. Maybe a tad on the warm side. Not one Thermal Cut to date yet. Using double 40x40x20 mm motor fans, with a fan mount . NO HS. HS's suck when the going gets hot anyway. Only works against you IMO. My temp gun does not lie.Curious what drawbacks you saw? I haven’t noticed any myself, but my use case may differ.
Have you popped it up on a corner weight scale? Factory setup, even with the handbrake removed, it had a mad rear weight bias.
The other beauty of the Treal hubs were it improved steering radius. Unfortunately I didn’t do a before and after, but it’s noticeable. It almost makes it roll again
I highly doubt a complete new FT release will be on its way. No one will know. Except HH. Info that's never released.It's a roll of the dice when holding out for new releases/versions. Maybe they'll release one, maybe the won't. Nobody knows for certain.
