GuyFromCanada
G'day folks, I picked up my first Li-Po over the weekend and finally got around to being home long enough to charge it and take it for a spin. This is my charger:
http://hitecrcd.com/products/charge...ni-ac-input-balance-chargerdischarger/product
and this is my battery:
http://www.greathobbies.com/productinfo/?prod_id=GENT50002S50C
I thought I looked over everything inside the balance mode charging screens, set everything up (5A balance charge, 2S) connected the battery, and started charging. The charger slowly ramped up to 5A and everything seemed good. Then it occurred to me that I didn't set a max charge voltage or storage charge voltage, or anything else like that so I stopped the charging. I went looking on the charger settings, and couldn't find anything else, so I went back to charge. Now when the charger is ramping up, it stops at 0.3A with the following message:
So I stopped and rechecked things and tried again...same problem. I used the battery voltage setting, and it showed the expected voltage for the two cells and the discharge connector. I put the battery in my Granite in Li-Po mode, and it worked fine.
Again I double checked the connections and put it back to charge...same error.
Did I do something terribly wrong by interrupting the initial charge? Is there something internal to the battery that could have gone wrong? Should I just run the pack now until it hits LVC and then try charging again?
