Gdub34
I recently put v5 6s shocks on my 3s typhon. The top mounts are all secured using silicone axial bushings to eliminate any play. I shimmed the bottom front mounts 2mm using M3 washers and the rear bottom mounts 1mm with M3 washers. I put the stock 3s screws to button everything up. My question is how tight should I put the screws. I tightened all 8 using my MIP driver and two fingers on the handle. They can definitely be tightened more but I was thinking it might effect suspension action by smushing the pivot balls. as you know the screws go into plastic threads which I don’t want to damage. How tight can I safely go with all 8 screws to hold everything together really well while not altering suspension performance or stripping the plastic threads. My a-arms are factory Arrma as well as my shock towers if that matters. How tight do you guys put your screws to keep everything together considering the shocks need to be removed and serviced periodically? Thank you so much for sharing your plastic /metal screw wisdom with me before I mess anything up ok
