- South Louisiana
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Notorious
- Talion
- Typhon 6s
Interesting conundrum. What say you?
Also sorry for the FB link.
Thats what I figured at first but then thought of guitar strings and harmonics etc. I'll see if I can find the entire thread to link. There are potential fixes but it looks to be too thin of a shaft, too long, or not tough enough steel, or need to split and add a bearing like the BRCC has on plastic shaft. Great opportunity for MIP etc if you ask me. Plus, how thick can we go if we're so close to that chassis brace?How tight is the fit of that shaft front to rear? Is there some play at the cups?
Haha I didn’t notice it was a @Aussie RC Playground video. I should have identified his voice. He’s far more qualified to answer this question than I am. I will kindly STFU and let him figure this out.Thats what I figured at first but then thought of guitar strings and harmonics etc. I'll see if I can find the entire thread to link. There are potential fixes but it looks to be too thin of a shaft, too long, or not tough enough steel, or need to split and add a bearing like the BRCC has on plastic shaft. Great opportunity for MIP etc if you ask me. Plus, how thick can we go if we're so close to that chassis brace?
I cant find it but it's at Arrma RC Army on FB. This is why I hate FB groups. Poor design and bad form to find stuff. I don't know why people start communities at FB for more reasons than that they're cucked anyway and untrustworthy.
Thanks for tagging me in this.Haha I didn’t notice it was a @Aussie RC Playground video. I should have identified his voice. He’s far more qualified to answer this question than I am. I will kindly STFU and let him figure this out.
Is there front to rear play in that driveshaft like the other 6S rigs? Or is it tight fitting in the cups?Thanks for tagging me in this.
Well, there has been some development and I've had others share their videos to me of the same driveshaft in their cars. Here's what I know so far;
1. A little vibration is normal, so if yours does not spin totally straight and true that's fine. However, mine is very bad and shouldn't be like that at all.
2. My shaft has been this way since new, I have not crashed the car at all and have only used it a few times, so there's no excuse for it to be this way. It's possible my shaft has been faulty from new and during running, it has gotten worse. The solution is to replace the shaft and hopefully it won't happen again.
3. I have been discussing this with some of the guys at ARRMA and they are very aware of my video and want to follow my results. They have not found this problem before, so could be the usual "reviewer's curse" thing and hopefully a replacement shaft will fix the issue.
Lastly, on my Facebook post some people have suggested making a bearing support for the driveshaft similar to that found on the 4S Kraton, however, that's not possible because it's a dog bone. ARRMA would have to come up with a driveshaft you can dismantle in order to fit some sort of bearing support mid way.
If you have any other questions, please let me know, I'll do my best to answer them. I should have a new shaft by the end of the week, so I'll let you all know the outcome.
Yes, there's play between the drive cups.Is there front to rear play in that driveshaft like the other 6S rigs? Or is it tight fitting in the cups?
Maybe try some rubber o-rings to snug it up but allow some flex? Just grasping at straws trying to help.Yes, there's play between the drive cups.
Appreciate that, thank you. The thing is that the shaft has a very slight bent in it and at high RPM it does what you see in the video. You can also hear it when I do my speed runs with it and that was the very first time I drove it, so it's been like this since new. So I don't think rubber o-rings will help in this case, unfortunately. I'm just gonna chalk this one down to a faulty shaft that needs replacing and once I install a new one, we'll see if that fixes it. ?Maybe try some rubber o-rings to snug it up but allow some flex? Just grasping at straws trying to help.
Does the shaft appear to be curved when out of the truck? Can you tell which way it is bent? You could try the @Mr.Duke 3 bolts in a vise trick?Appreciate that, thank you. The thing is that the shaft has a very slight bent in it and at high RPM it does what you see in the video. You can also hear it when I do my speed runs with it and that was the very first time I drove it, so it's been like this since new. So I don't think rubber o-rings will help in this case, unfortunately. I'm just gonna chalk this one down to a faulty shaft that needs replacing and once I install a new one, we'll see if that fixes it. ?
It will be so little it will not be visible.Does the shaft appear to be curved when out of the truck? Can you tell which way it is bent? You could try the @Mr.Duke 3 bolts in a vise trick?
Some of the guys that make their own parts on CNC could make a split hub that clamps to the bone for the ID of the bearing and a stand/mount for the OD of the bearing to mount to the chassis. The ID of the bearing just needs to be large enough to clear the ears of the bone. Balancing the hub could be a chore... but once you figure out the weight, that could be dealt with.
Are those made specifically for the Infraction/Limitless or do they just have dogbones in different lengths?I have ordered these 8mm driveshafts from Amped RC. No more flexy, bendy shafts. ?
Nice! Steel or stainless?I have ordered these 8mm driveshafts from Amped RC. No more flexy, bendy shafts. ?
