Granite Power Module Screws Threadlock?
MrLimey
Can anyone tell me if the power module cover screws get thread lock? It looks like they screw thru into the metal motor mount. And they appear to have white colored thread lock on them from the factory. So I think so but wanted to check. Thanks!
Can anyone tell me if the power module cover screws get thread lock? It looks like they screw thru into the metal motor mount. And they appear to have white colored thread lock on them from the factory. So I think so but wanted to check. Thanks!View attachment 228557
I normally put a little locktite blue on them. IMHO
+1
Metal to metal Fasteners are always Blue TL'ed.
Clean the screws well before reapplying TL.
TL Must Cure for the better part of a day before use. Not cured , it can even loosen quicker.
Thanks. I don't have anything to clean the old thread lock off with so I guess I just wipe them down and add more?
Use alcohol or any cleaner. Even Windex Cleaner or similar is better than nothing. A small Brass wire brush I might use at times. Sometimes the Screws become toast at some point . Constant re-application of TL ruins the threads. What I noticed. They can strip.
Ideally you want an automotive Brake Cleaner Solvent spray of sorts. Best.
Old TL is stubborn to remove. Sometimes not getting all of it off.
I use Loctite Blue 243. TL. It is Oil and dirt friendly.
Some guys actually use a Torch to Burn it off the screws.
Thanks. What's weird, is I have watched tons of videos about checking the gear mesh, and cleaning out inside the motor module regularly (why I took it apart today) but no mention of using threadlock to reassemble so thanks for the help. It is definitely metal to metal screwing into the motor mount so it definitely seems required.
That is not a very critical needed place for TL in general. IMO.
Not a 4x4 guy myself , so I don't know best......... Others may chime in regarding.
But if definitely Metal to metal, the tiniest drop of TL on the bottom threads is all you need, TBH.
In my opinion, you don't need it. The only reason I can see needing thread lock is for metal to metal contact with a metal fastener. In such case, you won't be able to apply enough torque to those small fasteners (without stripping) to keep load on the thread and keep the fasteners in place during vibrations and stresses. Anytime you have a compressible involved (gasket, spring, etc.--in this case, a plastic power module), the elasticity of the compressible creates constant pressure on the threads when you torque the screws; this prevents screws from working their way loose during vibrations and stress.
FWIW, mine came with some black gunk on the threads that I promptly removed. Taken the power module apart and put back together several dozen times on a few trucks and it's always held together with no thread lock used.
After owning my Arrma outcast 6s for the past 2 weeks, almost everything has come loose and needed to be threadlocked. Even the screws that hold the motor together.
Make sure you let it cure!! The most important step to threadlocking anything! Even in the automotive world. Seen way too many new mechanics threadlock stuff and the bolts come loose faster if not cured.
^^^ You are right. Anyone who has worked in Automotive repair knows this. Wet, Un-cured TL remains almost as a lubricant and loosens faster.
Just the opposite of what you want.
TL Needs to cure.
I use Blue 243, not 242, Loctite Brand for my RC rigs. Red only for my scale Cars, large hardware. Applying "Less" is More". And "More" is Less.
TL is very expensive. Better to buy a 50ML large bottle over a small Tube. Lasts for years. Bottle dispenses better, less waste vs. a small tube.
https://www.henkel-adhesives.com/us...stry-insights/how-to-apply-threadlockers.html
Edited.
If all three components (piece 1, piece 2, fasteners) are metal, then yes thread lock is absolutely necessary. If one of those is plastic, my answer would be: it depends, but likely no. And yeah a large majority of the fastened connections on the 6s stuff are all metal, quite different than the 3s line where almost all connections involve some sort of plastic component.
You can usually tell if thread lock is needed by gauging how much continued twisting is possible after the nut/bolt initially seats. If you can keep screwing for a turn or two and the turning becomes more and more difficult (building torque), then you should be fine. If it feels like you "hit a wall" and you suddenly have to start giving lots of torque, then it likely needs thread lock. Just my two cents.
For real though, the temptation to go out and drive a truck you just repaired is strong!!!! When you should be waiting for that TL to cure.
If I am out in th field bashing, and do a repair that needs TL, I won't use any TL at all, if I want to continue bashing. The Screw/nut will remain tighter than if using wet uncured TL. For instance, changing a Pinion out. I won't use TL on the Pinion Grub screw and motor mount slider screws. Better left dry of TL.
Air has to release from the TL in the threads for it to cure. Only Time will do this. No way to accelerate this. 24 hours.
The screws did ‘hit a wall’. I don’t think the plastic is threaded and it doesn’t compress much. I
I've never used it on mine.. its really just a case/cover and I think since the 2 plastic pieces are sandwiched, it doesn't require much "torque" to properly seat it to the motor mount!? I guess u could use it if u wanted too!?
You can usually tell if thread lock is needed by gauging how much continued twisting is possible after the nut/bolt initially seats. If you can keep screwing for a turn or two and the turning becomes more and more to difficult (building torque), then you should be fine. If it feels like you "hit a wall" and you suddenly have to start giving lots of torque, then it likely needs thread lock. Just my two cents.
This is very true as well, if your screws come out of plastic often, what you truly need to do is either use larger hardware to cut into the plastic and create a bond, or replace the part truly.
Same story here, I have not had those back out on me (no Loctite). I suspect its due to the plastic housing actually acting similar to a lock washer and preventing reverse movement on those screws. (y)
For the motor screws, I definitely Loctite those.
Thanks everyone for the input. I had a brainwave to check the technical sheet that comes with the manual, and it showed threadlock so I erred on the side of caution and that’s what I ended up doing. But I agree that it probably isn't strictly necessary.
I had to dig the technical sheet out of a closet given HH doesn’t offer it as a support download which is weird. As it’s more useful than the actual manual.
The mesh was tighter than I would have set myself, but I didn’t see any sign of abnormal wear after 15+ packs so I left it alone. The spur gear is surprisingly true to round so maybe that helps (if it ain’t broke…)
Side note the power module design in general seems to suck. Needs prying to remove and it’s a bear to get back in unless you line up the power module and diff shaft just right 😕 or maybe there is a trick to it I am missing?
