cancelthefuture
- Granite
- Granite Grom
- Infraction
- Outcast EXB
- Senton 3s
- Typhon 3s
- Vendetta
I thought the limitless v2 spool would be a drop in for the infraction, and even checked the part numbers at the hobby shop. Apparently I was looking at the exploded views on the v1 limitless or something because upon trying to install the spool, it's pretty obvious this just isn't going to work. I tried looking up the limitless v2 driveshafts and noticed it was the same part number as the Notorious driveshaft, but that doesn't fit correctly either. So now I'm sort of stuck between a rock and a hard place. Has anyone successfully put the Limitless V2 spool into the Infraction? I thought with same wheelbase this wouldn't be such a hard task to pull off but somehow the limitless chassis design must have the motor mount more centered than infraction or something.
The Notorious dogbones definitely don't stretch the whole way, and I'm not sure if there are any other parts anyone has in mind? Is this just a lost cause?
