- Thread starter
- #21
Skyrc. Got it off ebay and it's a must for any motor guy.What type of "motor analyzer" do you have? I'd like to get one for my experiments.
Wow. Calibrated my setup and disabled the LVC and it's not doing it as bad but it's still cutting out at top speed. Always, same thing, after it coasts for a few seconds it will drive again just fine. I guess I will replace some connectors and see if that helps. Rolling on the trigger definately helps. Not as bad once we quit stabbing the throttle at about 80ish. If the LVC isn't what's cutting out then, is there something else in the esc that can cut out? Is there some sort of max amps safety thing?
What I can't understand is if the max 6 can run a Losi DBXLe then why can't this larger model handle this application? If I had a bigger pinion would that make it worse or better? I can see it going either way. I mean, our top speed today was 96mph with a Cordova motor and max 5 but I imagine I could get close to that with stock setup. Is the motor freewheeling too much? I've got a 29t pinion and whatever is stock spur / spool.
This is puzzling me. The fact that it always starts going again and the steering never stops.
I will replace the connectors and maybe put some thicker motor wires but I just have the feeling that's not going to be it. Could be wrong though.
