Notorious PROJECT 100MPH NOTORIOUS
So i put the shorter steering blocks and hubs back on.time to start looking at aerodynamics,1/2in narrower on each corner so it'll cut through the air A little better. Swapped notorious siderails for senton6 ones.pulled the fans,not needed right now.hopefully truck is still stable an going straight next session.
I vote for 106!
Im Gonna give it to her till she takes flite or gets totaled.planning on castle 8s or xlx2,ordered 40t spur,⁹ gonna get with Phil dog for a cappack.wanna try some 8s parallel setup..4 smaller 4s packs.also gonna play around with some lightweight vs loaded down with packs.COULD THIS BE THE FASTEST NOTORIOUS IN THE WORLD??????😂🤣😅I'm so impressed by it putting the power down in swb under 10lbs and on 8s.i got some practicing to do.
I really love that rig. 👍 in good taste for sure. I know that can hit 100MPH easily. You have setup nice and good gear.
Makes want to build one like yours after my quasi 1/6-17 'ish Typhon is done.
Got new gears for notorious.i did 83 on 6s and 101 on 8s with 27/46 gearing.now ill try 30/40 on 6s an try to beat 100.on 8s gear calculator shows 164mph on 8s so would hit 130s if all went well I think.
Gonna work my way up.im at 101mph also gonna try an run sat if wheather let's me..
Ya we got snow today so no runs for me for a while... That's ok though gives me time to get the new 30t pinion in the mail. Hoping about 110mph with the 4 tooth jump🤘
Where did you get that 40 diff spur from?
Running TP 4050? Is that what I see there. Not sure.
TY
I was looking for 40 ish gears (RRP 👍)
That TP4050 looks good for me.
Ebay,Robinson racing...Tp4050-2100kv (40×81)
ABSOLUTELY AMAZING MOTOR.
@Edough13 you should get a tp.great motors
SWB chassis will hold upto 4060 (40×92) with stock motor mount location. I've got the 2100kv,runs cool on 8s.if u ran only 6s you could get up to 2700kv.the tp4050 motors have 60,000rpm max.these are the regular motors too.the cm race motors are even faster i guess.ive bashed off road on 8s in mojave and ran 101mph with this motor.way more power an runs cooler than my same size leopard.night & day.heres you gearing with -3v from sag.
@Edough13 heres with tp4050-2310kv.
This motor would still take 8s i bet.its nowhere near 60,000rpm at 19volts
Maybe with taxes, maybe, but with having just lost my job and still waiting on unemployment to come through or a new job funds aren't exactly there for a new motor at the moment unfortunately... I'll see at least how far the spektrum 2050 or BLX 2050 will go as I've got a NIB BLX I may try as well see which is faster for s&g's
Little more work to do an im gonna try an run it tomorrow.waiting on C-fiber sheets to come to close up some bad airflow areas before full send.shes geared for 130s on 8s..running white grps on front so I can tell which is front of truck when turning around way down road.been having some problems turning around lol... Lotta changes from 101mph run.strapped 1500mah 2s hump pack to run fans.cut out receiverbox up to fit gnss into...still need 8s cappack for bigger volts.
Worked on blocking off more areas where air could get under body,going airborne at speed is not good.got some new 4s packs on way an full send will be badazz or badazz crash.either way it'll be badazz.heres calculations for 8s at 28 volts..
