- Thread starter
- #41
Yeah, I read a "normal" diffusor angle is like 7-10 degrees. But it is also important to get clean high energy flow towards the diffuser, which is probably not the case because of an exposed front suspension and many holes in the chassis. But it looks betterThat turned out really nice! It appears your angle is far more realistic than the 25 deg. that Arrma used on the Limitless/Infraction/Felony.
I am in that same school of thought that the air gap under the car is too tight to allow enough airflow. There will be a boundary layer interaction with the bottom of the car and another with the ground. I don't think there is enough gap between those two for an under-car venturi to be useful.
BUT I have been wrong before
Ground effect on rc cars is not as powerful like on 1:1 cars, Maybe a higher ride height is better to stay away from ground boundary layer...
When the diffuser angle is too big and/ or not enough airflow under the car: The air gets suck back into the diffuser.
This car has too much rake, so not much air getting towards the diffuser.
Now I can sleep better...@Lennart Don't worry about the 1717. You hear about all the 5 people that grenaded them but you don't hear about the 10,000 people that haven't had any issues.
I've run my at 55K RPM for speed runs with no issues, with that said, it could blow into pieces at any time. But it is what it is and I will run it till it doesn't work anymore. It's not something I worry about. Would I bash with tall gears and high RPM - ah probably not.
As for the temp 65°C is fine and shouldn't be even close to anything damaging. There's also a difference between running temp and resting (storage) temp. When I do a speed run, I might see 75-80°C when the run is done. If I let it sit, the temp gets much higher which tells me the temp sensor is starting to read the true temperature or the sensor is out of range and doing weird stuff. Either way it's just sitting there with no stress on it.
Their isn't much in the motors (magnets, coils and some sensors) I don't believe it's an electronics issue. Which leads me to believe the temperature issue (others pleases chime in) is mechanical. The first is the bearings and lubrication. The second is the thermal expansion. The third might be any insulation or bonding material thermal limits. But, again hot is different than hot under stress.
BTW I'm sure (or at least I hope) that Castle tests every motor that goes out the door for max RPM to make sure it doesn't fly a part.
