PSA: Pinion Gear Puller
bicketybam
King of Bling
ArrmaForum Fan
New Milford, CT
Granite, Kraton, Senton, Typhon, 4x4-Mega, Notorious, BigRock 4x4
After doing battle with the pinion gear on my brand new Typhon, I went and picked up one of these. From the factory, Arrma uses an ungodly amount of loctite on the pinion gear set screw and it gets on the shaft. It took me 30 minutes last night to remove the factory pinion and I beat the hell out of the motor mount in the process. If I had a pinion puller the job would have been over in 5 minutes and my motor mount wouldn’t have been harmed. I’m new to electric so I didn’t have this tool in my box. I do now. For $24 it could save you a ton of aggravation.
bicketybam
King of Bling
ArrmaForum Fan
New Milford, CT
That or a lighter
I used a torch and still couldn’t knock it off easily. There was so much loctite on there. Trust me when I tell you a lighter wouldn’t have cut it.
WoodiE
Kind of good admin
Staff member
Lexington, KY
That's actually pretty dang clever. I like it! :D
bicketybam
King of Bling
ArrmaForum Fan
New Milford, CT
I've only really needed one with brand new vehicles. I got the Kraton one off after a little bit. But the Typhon one wouldn't fit though the motor mount and it made it really difficult.
Mr.Duke
NC
Outcast, Talion, Notorious
I fought with the stock pinion for 20 minutes and ended up heating the set screw with a soldering iron and my wife's clothes iron on the face of the pinion.
I should probably go ahead and order a puller just to save me future aggravation
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast, Typhon
I ended up cutting my stock pinion off, had to chop the damn thing in half. The grub screw insta stripped on me.
olds97_lss
Bash Break Repeat!
ArrmaForum Fan
Dekalb, IL
Outcast
Mine was stuck pretty good on my outcast when I got it. I used a mini torch on the pinion directly until it was pretty hot, then it slipped off pretty easily.
That puller does look like a good thing to use though in general. Then your not putting any strain at all on the motor shaft/magnet.
TooTall
ArrmaForum Fan
Kraton, Nero, Talion, Typhon, 4x4-Mega, Notorious
@bicketybam can you tell us what model/part number that puller is and where you got it?
TT
bicketybam
King of Bling
ArrmaForum Fan
New Milford, CT
TT
I got it from my local Hobbytown USA. It looked like it was sitting there for 10 years.
Similar threads
