- UK
- Felony
- Mojave EXB
- Notorious
- Outcast 6s
- Typhon 3s
I've been running a 15kg stock 6s Arrma servo (pulled from a Notorious) in my 3s Typhon. It's seen around 20 packs in all but it has just packed up
Steers to the right perfectly, but jitters and stutters slowly back to centre and is the same story when turning left. This happened after a small, even jump off a backyard ramp on to short dry grass about 15 mins into a run on 2s
Pulled it apart and carefully checked all teeth and bearings and they are in great shape. Servo lead/plug is fine and even the motor spins as freely as it should. It's not the servo saver or anything jammed as I've already fitted another servo in the Typhon which works fine
Does anyone know what the issue is? Is it likely to be the circuitry? I'd like to repair it if I can!
PS, yes, I have always set my end points ?
