Senton Replacement tire for Senton?
T
Yes, that is the correct tire if you are looking to stay with the stock tires.
Thanks for the reply.
Stock tires are best for me, but unavailable at http://www.arrma-rc.com/ & TowerHobbies, and so on.
I want similar tires with stock tires about width and diameter, etc.
Is there recommended tires at TowerHobbies ?
Not sure about tires, but DE Racing makes a wheel that fits 17mm hexes. The Desperado.
As far as I know, they are the only ones outside of the Arrma wheels.
I'm in the same boat though. Blew out my front tires.
Those DE wheels are the only ones that I have found for 2.2/3.0 short course tires with 17mm hexes. I have like 4 sets of them, and they work great, but I wish that there were more options. I have also used buggy rims and tires on my Senton but don't care for the rim to sidewall ratio.
Thanks for your information.
I am glad to meet you.
I found DE Racing Trinidad Short Course Wheels SC8/SC8E Black.
Good width,diameter,hex size.
I'm looking for good tires.
(Stock tire size: width 44mm, diameter 105mm)
I like Pro-Line Street Fighter SC 2.2"/3.0" Tires F/R, though this is not for off-road.
the Duratrax lockup's above are really agressive, similar to Proline Badlands. One suggestion for the front tires would be Proline Trenchers. Their tread pattern allows for more side sliding, which will help reduce traction rolls when turning at high speeds. The rear tires can stay the same with an agressive tread pattern.
