MMoelmann
- Illinois
- Fireteam
- Granite
- Mojave
- Notorious
- Outcast 8s
- Talion EXB
- Typhon 6s
I decided to upgrade my arms on my V5 Talion with RPM EXB arms and I had 2 sets of rear arms break within 5 minutes of using them. After looking at them closely after I noticed that there were air pockets in the arms where they cracked (see photos). I emailed RPM and they stated that I was using them in an extreme manor and they would not warrantee them. Am I wrong to think that jumping a 1/8 scale vehicle no higher than my head is not extreme?
Here is a quote from their response to me:
"Small air pockets are common and acceptable in thick, molded components. We don't use vacuum assist on our injection molding machines so small air bubbles are inescapable. When used under normal operating conditions, those air pockets would not be a problem. It's only during extreme use that they ever come to light.
You defined a "small" jump as one that doesn't go higher than your head. In no way is that a "small" jump. That's 6' of air pancaking onto flat ground in temperatures roughly 10° over freezing. Unfortunately, the conditions you're using your vehicle in are considered "extreme" and outside the bounds of the RPM warranty program. Our warranty policy is basically a modified materials and workmanship policy that includes coverage for breaks that probably shouldn't have happened. Head height and higher jumps onto flat ground, especially in cold temperatures, tend to fall outside of those qualifiers."
