I made up my own,but only when using two batterys.With a single battery a xt60 is weak( current handling).Buy or build adapters. You may lose some performance but lots of people do it even on the Nero and that's a power hogging beast.
I also made another adapter to run my Caslte bec to run my new Bls42a servo.![]()
There aren't many packs out there that have xt90's on them. My local hobby shop had (2) but they were expensive.I was in the same predicament. I went started ordering my batteries with the XT90 plugs already on them. For my other two packs that have a Deans plug, i have a Deans to XT90 adapter i use for now. After that im going to solder some XT90 plugs onto those packs.
I understand this thread is old...I'm new and in the same predicament. Why?If your going to make the change consider Xt150. You won't regret it.
This is why on 1/10 race cars everything is directly connected to the esc with as little wire as possible. Every connection adds resistance and the wire itself even adds resistance to the circuit as well. The more resistance that you can get rid of the more efficient the power system will be.Current is what makes the truck go!
It's debatable if xt150s are needed, but generally a larger connector means less resistance, which means less energy is converted to heat.
More juice comes through, less is wasted along the way.
without being over technical, how does more current equates to better performance?
More can be better, but sometimes enough really is enough. And XT90 plugs are enough for a normal 1/8 power system.Current is what makes the truck go!
But more plug is more better! ?More can be better, but sometimes enough really is enough. And XT90 plugs are enough for a normal 1/8 power system.
After I converted my rcs all over to XT connectors, I found black XT connectors and was like son of ****** I want black ones but don't want to have to swap them all out again.I really need to quit being an idiot and change from TRX to xt90's or 150's. I think 90's are large enough as I don't intend on ever getting into 1/5th scale, or an Xmaxx. Just don't want to spend the $50+ on connectors (I need like 30 for all my packs, trucks, chargers) and a few hours worth of soldering to do it.
Maybe I'll do it this winter... I think I said that last summer. lol
