BigKid
- Kraton 6s
Broke this part today. I cant seem to get it off the shock shaft. Do I need to take the shock apart? I don't see why I would. I tried holding the shaft with some needle nose and turning the rod end but cant seem to get it off.
I ordered the following to replace it. The picture shows the threads on the outside while the stock rod end threads from the inside it seems, unless it is just pressed on.
https://www.amainhobbies.com/hot-ra...luminum-shock-end-black-hraaon154x01/p1164509
