smirkracing
- SF Bay Area
- BigRock
- Fireteam
- Gorgon
- Granite
- Kraton 6s
- Typhon 6s
@parcou thanks for your advice. I received the tekno driveshafts. However, there seems to be a slight issue... first off, the instructions say " a very small amount of material may need to be removed where the outdrives exit...", but they don't really specify what they mean. Here's a pic of the instruction sheet:
Second, when I reassembled the gearbox, one of those plastic 'housings' that goes on the outside of the outdrives is totally bound up. Here's a pic (since I am sure that description did nothing for anyone):
The only solution I see is hitting the entire inside of the problematic housing with a dremel and removing maybe 1mm (or less) of material all the way around the inside of the housing such that it doesn't bind up the outdrive. Before I do that, I wanted to check with the experts on this thread... I can't be the only one experiencing this issue. Is this what the instructions mean when they refer to a small amount of material needing to be removed?
Thank you!
Thank you!
