Kraton Those dang tires wo t stay glued
Any suggestions on what adhesive to keep my tires glued I used gorilla glue as well as others none worked,yes I cleaned the wheels first
You can try an actual RC tire glue might hold better. I'd suggest giving the glue a good 2-3 days time to fully set and cure though before running👍
Super thin CA and just run it around the bead. Anything thicker will cause issues. Using the rubber based as well but super thin is my go to.
Use this video as a guide.
Krazy glut has been my go to for some time. Nice clean surface and don’t go crazy with the glue
