Any tips for installing the sensor wire on a Mamba Monster X? After taking off the sensor dust cover, it just seems I'm fighting the plastic shroud in order to get the sensor wire aligned - any way to easily remove the shroud or align the pins? I see there are seven pins and based on the diagram, I'm assuming the seventh pin closes to the + terminal is unused.
Not sure why I'm struggling so much with this ... probably ID 10 T operator error but curious if there's some tip I'm missing.
Thanks.
Thanks.
