Hi, I have just bought a 4050 1570 kv motor for my infraction. it came with m3 motor mount holes will it be ok to remove the end cap and drill and tap existing holes to m4 to fit arrma mount
Yes it will be fine. My first TP motor came with both end caps so I could change to M4 if needed.Hi, I have just bought a 4050 1570 kv motor for my infraction. it came with m3 motor mount holes will it be ok to remove the end cap and drill and tap existing holes to m4 to fit arrma mount
Have you run this setup yet?Hi, I have just bought a 4050 1570 kv motor for my infraction. it came with m3 motor mount holes will it be ok to remove the end cap and drill and tap existing holes to m4 to fit arrma mount
not yet due to a combination of work commitments and bad weather I haven't been able to. I'm not expecting it to be any better then the 1650kv hobby wing setup i removed on 6s but on 8s who knowsHave you run this setup yet?
