Logan's_Rcs
Good morning
I recently stumbled across this video:
that describes how to calculate the amount of energy loss (heat) from a brushless motor. I took these values to calculate the loss from TP motors, as I have used a couple in the past, and found some interesting results.
First, I used to run a 4060 1730kv, and it got hot in everything I put it in. Couldn't even keep it geared for around 50mph for bashing without it getting hot. I got another one, and the same thing happened, so it was unlikely a defective motor. I used these calculations in the video, and found that this motor's losses come to a total of 245 lost watts. I then compared this to the 4060 1350kv, using the same voltage, and it appears as though the 1350kv is more efficient because it's losses only come to 171 watts of waste heat.
Now my question is, just how much power is 74 watts? Is that a decent amount of energy to be gained in the 1350kv, or does it not really matter? Would there be a big difference in heat between these two motors?
Thanks for your thoughts!
