Lol had extra fans so I decided to make 3rd and boom heat it is
And fully functional now have to find a 3 way female splitter and I’m good.
Probably depends on the servo, but I think most of those high output 10k 30-35mm fans pull .20 - .25 amps. The <=7K rpm fans are usually listed as .15-.18 amps.Gotcha... I was gonna say, I have perfect temps with 1 fan and no heat sink...
Just a thought but, do you think that's taxing on the bec output?
Servo is savox 1210sg with glitch busterProbably depends on the servo, but I think most of those high output 10k 30-35mm fans pull .20 - .25 amps. The <=7K rpm fans are usually listed as .15-.18 amps.
I’ll try that method outThen yeah, if your running the blx185, your pushing the internal BEC pretty good when your really running it hard in rough terrain. The 1210sg pulls 6A on stall @6V. The BLX185 bec is 3A constant, 12A peak BEC.
If you don't hear the tone of the fan whine dip when you steer, your probably ok. I noticed that on one of my trucks with a castle esc and that was with a far weaker servo.
