- Outcast 6s
?Any guidance or how to advice , instructions would be appreciated ...Thanks ?
If I were to get only one 6s rig, it would probably be a Kraton for my type of terrain.
I like to offroad and jump mostly
Thanks, yes.... It certainly would be another option worth considering.
Just how tough is the Kraton compared to the smaller lighter Arrmas ... do you break many parts jumping?
If it won’t come out easily add a little heat with a soldering iron. Leave the soldering iron on the screw for like 5mins and it should come out easy after that.How do i get the existing front pieces off my V4 typhon ? is the only way to heat up the grub screw that goes through the center ? it’s really in there !! or is there a short cut to take the whole piece off ?
ok thanks for your help !!If it won’t come out easily add a little heat with a soldering iron. Leave the soldering iron on the screw for like 5mins and it should come out easy after that.
