Mike-NLD
If you want your kid to drive the car.. How old is he?
Id say.. Leave the spektrum in there for a while.. The spektrum radio has a 50% 75% 100% trottle switch on it.. So you can drive it flat out.. And when you hand over the radio to the little one.. Tune it down to 50% and 75% later on.. When hes ready to drive it flat out.. Then put the TXX in..
And just hope for the best the spektrum you get is good and doesn't get you to get a run away V4
Or maybe even put in both receivers.. Theres more than enough room in the box to fit both.. If you drive it.. Take the TXX.. When you give it to the little one.. Just switch out all cables.. Takes like 5mins imo..
Cons: switching cables
Pro: engine cools off when you are switching cables
Also.. Bein said its a 4s/6s car.. If you take a 50c 5000+ amp 3s Lipo.. You can also run it on 3s..
