Typhon 6S V3 all-round build
Netherlands
  1. Mojave
  2. Typhon 6s
May 1st, 2019
Just bought the 6S Typhon. She looks so good!
June 4th, 2019
I had to glue them back together, the tire wear was not that bad but they were ballooning a LOT.
June, 22nd, 2019
Picked up a motor fan for the BLX185! Now I can run the 6s without problems.
June 27th
2 pairs of Louise B-Rockets and 2 pairs of Louise B-Pioneers. Much better compared to the stock tires.
July 1st, 2019
Did a bit of maintenance work on the Typhon
August, 17th 2019
The rear diff was full of dirt, it sanded my gears down ☹
Yeah that is a blasted diff looks even worse than the one I filled with sand. Get the repairs done and bash on that’s what we do. ????
May 1st, 2019
June 4th, 2019
June, 22nd, 2019
June 27th
July 1st, 2019
View attachment 48629View attachment 48630
August, 17th 2019
I had the identical issue after two weeks with that rear diff shredding the gear. How are you going to stop it from happening again?
You could you gasket sealer under the housing where it meets the chassis to seal the gap to stop ?? getting inside..??
I will be doing mine soon as the housing had fine sand inside it....?
