Typhon Typhon 6s V3 ESC question
palmryde
  1. BigRock 4x4
  2. Granite
  3. Typhon 6s
Hello all, I have a question. Can is use my arrma ar390211ic blx185 motor with a new Speed Control firma 150 spektrum ESC?
Sure, I believe it’s the same motor (2050kv) but the new one has no ridges to increase surface area for cooling.
Yes it is the older motor not spectrum, so the new spectrum esc will be fine then, Correct?
Yes, the new esc is actually a rebranded Hobbywing max 8 and the blx185 esc a hobbywing quickrun 150. Both are similar and will run either blx or spectrum motor just fine.
