OrangeDRAGON
I honestly didn't think they would fit/work. Other wheel/tire combos didn't work because there was no turning radius available (needs more offset). But the SRC's incredibly massive huge rims allow full lock-to-lock turning when the suspension is at normal ride height. The only time the turning binds is when the A-Arms are extended and then at about 85-90% steering it will make contact with the shock spring. A simple adjustment on the droop screw and dial back the endpoints a touch and problem solved.
