Depends indeed a lot on the type of driving.I get about 20 min of light bashing on the stock setup with Powerhobby 8000mah 100c, But if I'm Sending it I get about 15min.
Wondering if it would make sense to stack 4s 6000mAh over each other. Two on each side. That would be about 9cm high. The lipo holder is only 4cm high. So it would need some kind of strap to keep it in place. But with hard bashing I don't think it would stay in place. Any suggestions?
I use aquarium mats. Very thin and are put under aquariums. Like a thin sport mat.
Double stacking won't do it if they are too high. Just looking at the Gen#s Ace 8000 4s2p. Any opinion on those?
If you wire each stacked side in Parallel, you can achieve 12,000mah on each side and wire both stacked lipo sides in Series. Ending up with 8s at 12k mah.Wondering if it would make sense to stack 4s 6000mAh over each other. Two on each side. That would be about 9cm high. The lipo holder is only 4cm high. So it would need some kind of strap to keep it in place. But with hard bashing I don't think it would stay in place. Any suggestions?
What do you mean with more fun? More power or because you also use them in other rc cars?
If you wire each side in Parallel, you can achieve 12,000mah on each side and wire both stacked lipo sides in Series.
Currently got 6 x 4s and 1 x 6s lipos, but the 4s lipos are also used in a Losi 8ight buggy. With a 20T pinion the K6 is still reasonably quick on 4s and wild on 6s.K8 is half the driving time of a K6. It's just double the weight and huge compared to the K6. If you like huge and have - why not... Do you drive the K6 on 4s or 6s?
With the build specs I'm looking at - both EXB's, the K8 would be £1,130 and the K6 would be £860. That's without additional lipos.You can just about get a Mojave and a K6 for the money you would put into a K8 with lipos.
