It’s hot in 5 to 10 min.Need more info.
1.How long of run times are you getting?
2. What gearing are you running now?
3. Have you checked the gear mesh?
Is it rolling freely?
4. Has it always had heat issues from day 1?
How old is it?It’s hot in 5 to 10 min.
Box stock gearing (16t pinion 50t spur)
Yes mesh seems fine, rolls freely
Not really that I’ve noticed
That not out of the realm of normal if you have a heavy finger or playing in the grass163+/-
My new v5 Typhon’s motor gets really hot on 6s with the stock gearing. Is it perhaps too tight of a gear mesh or should I install the bigger pinion when running 6s?
Hopefully this Amazon special will fit with a little modification. It appears to be on the proverbial slow boat from China... it looks like it will be a while before I can post an update on the fitment.If you can get the heat sink and fans to fit under your V5 body post some pictures and part numbers please
Rather than start a new thread I though I would post here.
I've had my Typhon a little over a week now and I thought it has always run too hot. I measured my motor after the last run and was shocked to see 89C after running out my 5200mah 6s. It was a cool day, about 20C and I was on an ultra smooth cricket field. Stock pinion. I felt this would be considered just normal use but maybe not? On the next run I found the motor was loose so mesh was probably not right, will check it again with the mesh corrected but looks like I'll need some cooling either way.
