Infraction Voltage Drop
CARPJR
Holland, MI
I'm runing an Infraction. Using Two Cheap 3S 80C 5200MAH batteries in series into a Spektrum 160A ESC (out of a Kraton) into a Castle 2200kv motor.
While doing short speed runs I'm getting a cutout at wide open throttle. My data shows minimum voltage dropping to around 16 volts.
Is my cutout caused by a couple bad battery cells? Is that unusually high voltage drop?
Running 29/34 gearing - it's a very heavy load.
Or is this just too much for that ESC?
You’re probably exceeding the amp limits of that ESC. You can do a few things:
1) Gear down until it doesn’t amp limit
2) Take longer to get up to full speed
3) Swap for a lower KV motor
4) Swap to a MMX8S or XLX2
5) Higher rated lipos (100C+)
