I really want to hear more about this. Like really really. What broke on the exb that's solid on the kagama?IME, the Kagama is more durable than the Kraton 6S EXB v2.
Same, if my asuga is anything to go by there is no way I'd believe that tbh. Maybe the kagama is more durable somehow but that asuga definitely not more durable than Arrma in my book.I really want to hear more about this. Like really really. What broke on the exb that's solid on the kagama?
Already watched it, thanks so much!
Parts are the biggest hold up for the TC I feel. They are generally available most of the time, but limited sellers. I truly like all 3 myself. I might choose the Arrma due to good parts availability and that many parts are interchangeable acrossed the Arrma 6s line, which I already have a few of. The TRX is good to, parts are available on the space station! I read on the internet that Elon and Mike Jenkins have a deal worked out so the Cosmonauts have TRX parts available..Already watched it, thanks so much!
Loved watching the Sledge lose almost every category
I can get the kagama for 558 or the exb for 560 with my coupons lol the EXB is probably a better buy?
Right on @razorrc I commented before watching, turns out I couldn't agree more,LOL. Well done sir.
Do RC bashed both in similar ways and the EXB resulted in broken upper, lower arms, and output diff cups.I really want to hear more about this. Like really really. What broke on the exb that's solid on the kagama?
The new diff cups do look like a let down I have seen quite a few people have issues with them.Do RC bashed both in similar ways and the EXB resulted in broken upper, lower arms, and output diff cups.
No it doesn’t fit the max length motor you can put in it is 82mm I believeAnyone know if the new max6 g2 4990sd combo fits the Kagama roller?
Can you grind off the bit plastic to make it fit?No it doesn’t fit the max length motor you can put in it is 82mm I believe
You may be able to not sure I don’t have a Kagama just saying what I seen and online I have heard some people have done that although I don’t know what motor they were usingCan you grind off the bit plastic to make it fit?
Yes I would say that would be a better setup for this car. Another motor that fits Is a rocket 4282 iv seen it on Jason perrins channel it looks super powerful.It should work
component size here is the (same). maybe the 49 diameter can size is to big.
it may also be overkill for this rig so prehaps this combo is better?
Hobbywing HW38010405 Ezrun MAX8 G2 Combo with 4278SD 2250kV
The only problem is that I have more use for the bigger system with other carsYes I would say that would be a better setup for this car. Another motor that fits Is a rocket 4282 iv seen it on Jason perrins channel it looks super powerful.
that max8 system should be perfect for what you want by the sounds of it or the stock Corally systems are really fast but I think they run hotter than the g2 systemThe only problem is that I have more use for the bigger system with other cars
