Arrmadog1990
Ahhhh this makes sense very good info my dude thanks !! Ya I’m not gonna mess with the additives didn’t really think about the lines being able to expand!! This is perfect I like simple and no heavy reservoirs!The extra coolant capacity is just a heat battery, and a heavy one at that. The idea isn't to store heat with extra coolant, what you want is to move heat via the radiator and get rid of it. You are using a flexible Tygon type tubing, which will handle any thermal expansion in your low-volume system. Keep it simple and easy to maintain. Remember, your car gets shaken up like that beer can your grinning buddy just handed you when you bash, so a bled system without air space (reservoir headspace) will survive the abuse without pump cavitation and stall, and boy do impeller pumps stall.
As far as chems go, knock yourself out (for science!). Be careful, you're going to get that stuff all over your car eventually, and you don't really know what's going to get eaten by the additives. A full scale car motor produces tens of kilowatts of heat, and a RC motor produces a couple of hundred at peak. A 5% improvement on the car's thermal efficiency is a lot of heat, but the same gain on the puny RC car system is single digits- so I argue the effort isn't worth it. Again, keeping it simple makes sense.
10-4 will do sir! Also I hope your wrong lol like you said only one way to find out! And we gonna find out that’s for sure !Honestly I believe temps will be worse imho. Just a prediction based on what I see on boats.
Air flow around cans is pretty efficient in these designs, but only one way to find out
When taking temps, check the front and back of the motor, don't fall into the cooling mantle trap like a lot of folks do.
The water mantle is physically isolated with rubber gaskets and relies on water/air transmission.
If all works, it's an ok indicator, but it will misguide if there are issues in water circulation.
Perfect! I’m officially doing away with the reservoirs you guys have convinced me and ya definitely trying to stay well under 180 Hahahha+1 on avoiding a coolant tank/revivor. I think keeping it much like a 1:1 car's cooling system is ideal.
I don't believe you would have any issues with expansion due to the flex in the lines and if temps got to 180+ you have other issues anyway...
