What did you do to your RC today?
Its been awile just wanted to show off my truck again.
upgrades
120a hobbywing esc stock settings
Rocket racing 3800kv 9t 4pole brushless 550 size integey heatsink and custom fan
3s venom 4000mah lipo
Castle bec
Tatic high torque servo
60wt shock oil (getting traxxas shock caps soon)
Everything else is stock. Figured i would show my bus off because i have been driving this thing HARD on and off road 25 foot jumps and wheelies all day. Only issues are heat when offroad with trenchers after 15min. And steering when on loose dirt.
Mainly been spending my time building a HUGE rc park with a few others. Check it out
http://www.bigsquidrc.com/event-coverage-2015-rc-freaks-springdale-park-bash/
Gonna be getting into 5th scale gas soon but untill then im gonna keep furthuring my start into the hobby
Today, I installed a 100amp wp-s8a esc into my granite blx and put the 120amp in my 1/8 acme dominator. The 100a super esc is almost as wide as the granite chassis!
Saturday; stripping out my first servo, then ordering a Tactic that afternoon.
Thanks again @BFH !
I was comparing my hotboddies lightning truggy pro to my talion
I think the a arms on my lightning is stronger than the talion
aluminum is going to be more rigid and "stronger" in some instance but keep in mind if your a-arms are not going to break then you need to follow the stress up to the next weak point and that's going to be your most likely break spot, if your going to bash your vehicles but want something that won't break easy it's actually better to create an intentional weak spot so you know that when something breaks its most likely going to be "part a". A-arms are a better thing to break then say a front bulkhead, shock, or shock tower. of course there is also the inherit risk that you may bend the aluminum and still break the bulkhead. Lastly keep in mind that every material has elasticity also know as memory or the ability to return to it's original shape what this means in simple terms is a plastic piece has an easier time flexing then returning to it's original state.
Don't mean to drag this off topic too much but just keep in mind on those a-arms. I'm just putting this out there from my own experience on busting a-arms on my vehicles I decided it was cheaper to replace an a-arm in most cases then the chassis and front bulkhead when I hit a tree wrong.
You have a good point
Youre right its much cheaper to repplace an arm than those bulkheads not to mentioned more hard work to get in to
It's only Monday, but so far I've run it up and down the street, did some cartwheels on an ill advised turn into the driveway, and chased the dogs around the backyard for a little bit with it.
add balloons to my shocks lol
and bought some cheap china tires off ebay $19 for 4 tires (need to be glued) but mounted here is what they look like...
