iball123456
- Felony
- Kraton 6s
- Kraton 4s
- Notorious
- Typhon 3s
Hi,
I’m new here so hopefully I’m in the right place, I’ve been lurking for a while and found lots of the posts very helpful and interesting. The how-to info has been invaluable.
I bought a Kraton 4s in January and got the RC car bug. My son is 12 and he then got a Typhon 3s for his birthday in May. The issue i have is my Kraton has spent more time broken than running. So far it has snapped A arms in relatively slow speed crashes, it has entirely melted the rear differential, melted the centre drive shaft, broken the slipper clutch, broken turnbuckles to name but a few things. I’ve only run the car maybe 10 times in total as every time i run it, something gets destroyed. I started running it on 3s and I’ve done a couple of runs on 4s which resulted in the melting of driveshaft and rear differential. I spend most of my time waiting for spares to be delivered and the car is currently in pieces awaiting a delivery of spares which are out of stock until mid-august!
When i bought my son his car i made sure i had lots of spares for him and to date he’s had no issues at all, everything has worked without hitch. I also feel bad as I promised him lots of father son time running the cars together and to date we’ve managed it once as mine is always broken!
So, i have 2 questions, have i been unlucky with my Kraton, or is this normal? I get a bit of repair is necessary and part of the fun, but should it really break every time i use it even when just hacking around a flat playing field? I also notice my go-to shop for parts has some Notorious 6s cars coming into stock later this week, should i order one and assign the Kraton to the recycle bin? Is the Notorious likely to last a bit longer especially if I stick to running it on 4s power?
Sorry, that was 3 or 4 questions, any help or advice appreciated.
Regards
Iain
Regards
Iain
