JaySuave808
Wish I had solid numbers for results but has anyone used this before?
This is paired with 1515 CC AND 1/8 sidewinder.
I have that exact same battery and it's been great.. I've cycled it a ton, beat the hell out of it, it's been completely submerged under water 2 or 3 times and still works good.. I've got 2 cells that our finally starting to go bad, they've got pretty high ir readings compared to the other 4 cells but it still has great power and good run time, and it's really lightweight for a 6s battery. When the one I have finally dies, I'll definitely get another one, and I believe they can be bought for $115ishI use this one and never had any issues. Seems like a good batt to me.
I paid $203 on amazonWhat do they cost? Its unfortunate that the C ratings are essentially made up. :/
Can you give more info where I can save $100?I have that exact same battery and it's been great.. I've cycled it a ton, beat the hell out of it, it's been completely submerged under water 2 or 3 times and still works good.. I've got 2 cells that our finally starting to go bad, they've got pretty high ir readings compared to the other 4 cells but it still has great power and good run time, and it's really lightweight for a 6s battery. When the one I have finally dies, I'll definitely get another one, and I believe they can be bought for $115ish
It is certainly on the lighter side.Their from a legitimate company so don't see why they wouldn't be ok.
https://www.powerhobby.com/ph-6s-6000mah-150c-ec5.html
Is it just me or is this battery pretty light for a 6S?
Specs :
Lenth : 132mm
Width : 44mm
Height : 58.5mm
Weight : 25.9OZ
Suggested Charge Rate: 2c
Wire : 10 gauge
Continuous Discharge: 150c
Max Burst Rate: 300c
Voltage Output: 22.2v
This needs to be a sticky in the battery/electronics forum: https://en.wikipedia.org/wiki/Anecdotal_evidenceYou are and that’s all that matters!
Check out the Lipo testing threads to see how subpar that battery actually is in comparison.
My question exactly. I have researched the hell out of this, the best I found is 169+tax on ebay, but "currently unavailable".Can you give more info where I can save $100?
10 gauge wire…Their from a legitimate company so don't see why they wouldn't be ok.
Specs :
Lenth : 132mm
Width : 44mm
Height : 58.5mm
Weight : 25.9OZ
Wire : 10 gauge
This is the battery I have that I was referring to. I know it's not the same battery you started the thread about, I was just letting everyone know that this one is a great choice for the 6s rigs... sorry for any confusion
