Groove Holmes
- Talion EXB
first diff build
It's not the original motor mount, as it has the one hole. Alignment is correct.After you’ve done a couple of diffs builds, you’ll wonder why you thought it was challenging in the first place.
On a side note, are you using only one instead of two motor sliding mount screws and its it the picture that the alignment of the center diff mount looks off? Does your center diff plate fit?
That’s one of the original style hot racing motor mounts. I have one as well there ever nice mounts I’ve had mine for at least 6-7 years. Terrible pictures I just happen to be working on my sons truck.It's not the original motor mount, as it has the one hole. Alignment is correct.
