- Maryland
- BigRock 4x4
- Felony
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Typhon 6s
This is the only way I think I can mount this pinion Only a couple mm from the mount.
That’s the old style mount. Can’t do that with the new.
That looks acceptable to me. You might be able to snug that pinion back another 1mm.This is the only way I think I can mount this pinion Only a couple mm from the mount.
I see your issue, this setup isn’t ideal but I agree it looks ok.. as long as you use a bit of loctite on the pinion grub screw and check it after each run to be safe..This is the only way I think I can mount this pinion Only a couple mm from the mount.
Cuz it looks faster than MPHI'm curious why someone in Colorado is measuring speed in Km/h.
The Hobao Chassis comes with slits in the chassis that are for the velcro straps.Hmmm, do you drill slits in the shassis, or is there some detention i can add on, ie, small carbon plate.
Wow there was more typing errors in that sentence then dollars I’ve spent on the car so far lol
letes try again
do you drill small slits in the chassis for the Velcro, or is there a small carbon (i would prefer) plate i can just screw in to drill into?
