Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
Grub screw. Try a grub screw instead of that silly Phillips head. The below kit is fantastic and I use them any time I need a grub screw (except for tightening the pinion). For pinions I use a flat point.So even the Phillips head screw off rpm Typhon arms that barely even reaches the pin enough to hold it takes away too much room to keep the wheels from rubbing. And I wouldn't shim more than around a millimeter or you risk ruining your wheel hexes so gonna shelf those wheels for now.
Gonna have to pick up some hex extenders after all if I wanna run em on the Granite
@GRC Your build thread is amazing btw I wish I would have seen it sooner would have saved me alot of headache/heartache.
You did save me $40 off m2c took your advice on just getting the motor plate instead of the combo.
How do you like the 2400 with the 18t? Still running cool geared up? I'm running the 3s motor till she blows but was on the fence about what to throw in next.
Most grub screws are cup point that have limited connection with the motor shaft. I haven’t had a pinion loosen once I started using flat point. I also use longer grub screws then provided, 12.9 tool steel and long as I can fit (5mm for most pinions I use). I haven’t stripped one of the longer screws out since I started using them.
