Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
So I stripped out the rear ring and input gears in my granite. It’s an easy fix but…why did it strip to begin with? In over a year I’ve yet to strip one. I recently installed cvds on the rear and a week ago put in a 3670 motor. I’ve been running hot racing yokes for a couple months.
I put a new one in last night but decided to pull it apart again this morning and check the mesh because I couldn’t stop thinking about it last night. I’d also forgotten to fill it so did that as well. Good thing as it was only 1/4 full from the factory. I filled it up with 20k, I’m running 30k up front.
Maybe with the combination of cvds and the hot racing yoke it needs a tighter mesh? Thinking this, I swapped the shim to the ring side and it was way to tight. So I removed the shim altogether and it seems good. A little tight but good.
I ran it a bit ago and all seems well. I’ll run it again tomorrow then pull it apart to check everything. Trial and error…
