DesertRC928
My problem is none of my 6s batteries will charge faster than 2.1-2.3 amps.
Doesn’t matter what I set my charging amperage at. All 3 of my 6s batteries cap at 2.3 amps.
My current charging/battery setup
Passport Ultra P2 (capable of 10 amp charge rate)
Also have a cheap turnigy (capable of 6 amp charge rate)
I have one 6s power hobby 6000 mah 150c battery I bought at my local hobby shop.
I also bought 2 cheap socokin 6s 7200 mah (lol yeah right ) 100c batteries off amazon.
I’ve also tried charging all three 6s batteries on my other charger with the same results.
I have some other 2s and 3s batteries that I can charge at any amperage on both of my chargers. This makes me think it’s specific to the batteries unless I’m missing some secret 6s charge setting lol.
Initially I only had the power hobby 6s that I bought with my charger at my local hobby shop. I showed them my issue with it charging slowly and they are going to warranty my battery through power hobby. (Waiting for them to ship the new one still) So I bought 2 more cheap 6s lipos from Amazon while I’m waiting on that and I’m having the exact same issue.
What the heck are the chances I have 3 defective 6s batteries in a row lol?
All the batteries seem to work fine other than the slow charge rate. Plenty of punch and run time seems to be sufficient. I’m running them in a 1/7 big rock 6s.
In the pictures I have the charging amperage set at 10 amps, but you can clearly see the charge rate is capped at 2.1 amps. With this issue it takes about 3 hours to fully charge which is super annoying lol.
Is there something I’m missing?
Any of you guys seen an issue like this before?
Any insight you guys can provide would be appreciated. Thanks.
