Hector_Fisher
Good points. Would this come down to a question of money and convenience? IE, if running high quality cell matched packs (costly batteries), you may not need a high balance current (less expensive charger), whereas if you have wildly ranging IR (cheap batteries), then you'd need a high balance current (costly charger)?One of the specs that is not often talked about but is the one that can really make or break a charger, is this one:
The bulk of the charging goes over the two primary leads of the battery up to around 4.15V/cell at which point the charger switches to balance charging in order to ensure that all cells achieve the same voltage when everything is said and done. To the surprise of absolutely no one, balance charging is done via the balance lead which, due to the small cross section of the wires, is only rated for a 2A load max. I know it might seem trivial but, it really isn't. Ideally you want your charger's balance current to be as close to 2A as possible as those last 0.05V can take as long (sometimes longer depending on the health of the cells and how in or out of balance they are in a given pack) as the bulk charge from storage voltage to 4.15V/cell. Hence the importance of a high balance current when choosing your charger. Just something to keep in mind while you're shopping around.
Good luck hunting!
Or would the high balance current still be beneficial even for well matched packs (shaving off significant time from charging)?
