werner sline
- Thread starter
- #21
interesting review man ! funny that they updated the truck by adding a paper ! could you scan it by any chance ?Werner: your videos are great!
I finally had a chance to run the truck this weekend. I'm a natural terrain basher and here are my thoughts. Turns well on loose dirt for such a big truck, but is awful when turning on a grassy field. I have a protek 170 black series servo and its fast and strong, but the grass renders it almost useless. I am going to tighten the servo saver and see if that helps. After my first run I changed the shock oil to 80wt, that made a huge difference in the way it handled and absorbed jumps. It felt plush like my losi 3xle with the shock oil change. Another annoying thing was the amount of grass captured on my rear axles. I'll have to created rear mud/grass guards for continued use in grassy areas. I also went up one tooth on the 1730kv motor from 18 to 19 and the truck woke up. It really needs a 20t pinion for this setup, but there's only room for a 19. I'm going to try a 2000kv motor and possible a 2200kv. The belted trenchers are about 5 mm taller than the non belted trenchers and keeps the power to ground. Now I want a set for my Kraton. Last item that I noticed was the turnbuckle measurements. The chassis came with the turn buckles set to the factory manual measurements, but my manual came with a one page update to the manual with smaller turnbuckle measurements. With the caution axles can fall out of diff cups if you don't adjust your rc before use. Now I know why the extra diff cups were in the box. This happened to me on a jump and sheared one of my rear diff cups. I made the adjustment and no issues. Overall this is a fun non-truggy, classic monster truck that is built extremely well.
Werner: thanks for the setup tips!
i guess they had somebody having troubles once so they immediately reacted for the next customers, that's actually nice !
the overall gearing needs indeed a higher kv motor. did you run the stock tires ?
did you change the diff fluids ?
