This thread will serve as the Arrma forum 2s speed run challenge.
Rules:
- Have fun and enjoy the journey
- Be safe and considers others' safety!
- Help each other improve
- Must be 2s voltage (any number of batteries parallel as long as it stays 2s LiPo max voltage) (4.2v * 2 = 8.4v max voltage post run) (overcharging or LiHv packs are allowed)(if your voltage is over 8.4 post run it will fall in the secondary HV list)
- If you are fitting in the top 5 spots on the list you need to show voltage after the run with a voltage meter as the others have done.
- Any motor (assuming we are ok with dual motors should someone want to run that, but will be split off onto a separate list)
- Any ESC (come on it's always the XLX2
- Any tires (Rubber or foam)
- Chassis any 1/8 or 1/7 ("1/10" cars like Slash 4x4 that are truly by size/measurement a 1/8 scale are allowed)
- (NO 1/10 scale small touring cars like 4tec, serpent, Tamiya etc)
- Standard rules for showing GPS that we normally do.
- In your video show the batteries are 2s (3 wires) and if running parallel clearly show the connection going to the ESC.
- Do not have to return the car, but crashes disqualify the run
****Post your video link in this thread and I'll edit the original post with a spreadsheet of standings a few times per week. Also note the car so I can keep up with the list. (I'll track up to 2 of your cars, but you must tell me the model of car in your thread post)****
(Optional if you want to share what motor, batteries, and gearing you are running. I am totally fine with you keeping that secret if you would like)
Rules:
Single Motor Cars | ||||||||
Ranking | Member | Speed in MPH | Cells | Car | Motor | KV | Battery | Video confirmed |
1 | slow rc mike | 125 | 2 | Hobao VTE 1:8 | Castle 1515 v2 | 2200 | 2p | Yes |
2 | slow rc mike | 122 | 2 | Hong Nor igt8e 1:8 | Castle 1515 | 2200 | 2p | Yes |
2 | slow rc mike | 122 | 2 | Hong Nor igt7e 1:7 | No | |||
3 | chris adams | 117 | 2 | Arrma 1:7 GT | TP4060 | 2p | Yes | |
4 | chris adams | 116 | 2 | Typhon stretched GT Body | TP4060 | 2p | Yes | |
5 | vwturbowolf | 115 | 2 | VTE2 1:7 | TP | 2p | Yes | |
6 | LibertyMKiii | 114 | 2 | VTE2 1:7 | TP4070 | 2p | Yes | |
7 | K-BASH | 109 | 2 | Vendetta | TP | 2p | Yes | |
8 | K-BASH | 96 | 2 | 6s Arrma 1:8 GT | 3p | Yes | ||
9 | LibertyMKiii | 89 | 2 | Limitless open wheel 1:7 | TP4050 | 2p | Yes | |
10 | Edough13 | 88 | 2 | Limitless GT 1:7 | 1721 | 2p | Yes | |
11 | Diem Turner | 83 | 2 | VTE 1:8 | 1721 | 2p | Yes |
HV 2s List | ||||||||
Ranking | Member | Speed in MPH | Cells | Car | Motor | KV | Battery | Post run voltage |
1 | slow rc mike | 126 | 2 | Hong Nor igt7e 1:7 | Poesidon 1515 | 2p | Voltage 8.7 |
