Arrma Fury replacement bodies
ark1t3kt
Illinois, USA
  2. Talion
Anybody know which lexan bodies fit the Arrma Fury SCT well? My stock body is bead up and has several cracks in it. I was planning on buying a Fury body, but am considering a Pro-Line (or other manufacturers) body for a different look.
Thanks!
ark1t3kt
Illinois, USA
  2. Talion
So I did a little more digging and found that the wheelbase for the Fury is the same as the wheelbase for the Losi XXX-SCT. The Fury is only 4mm wider and 10mm shorter, so the Pro-Line bodies that fit the Losi XXX-SCT should be a good fit.
justatree
Thanks!
do you know if the senton body might fit the fury? I personally like the vents and that clear rear wing ;)
FPA4
Canada
  2. Granite
Reviving this thread, my son’s Fury is about to become two parts, wondering if anyone has tried a Senton body on the 2014 Fury chassis?
