crankestein
that truck really has gone through a lot, am glad you are taking care of it.
Pictures are a plus for the thread
Nice truck. I have one too. Had the same shock snap and had to buy new spring perch. Diffs too. My slipper came loose several times. Blue loctite helps. I do 1 and 1/4 turns from tight and it seems to work. In the beginning I had it completley tight and stripped my diffs. Now I set it loose but it's hard to keep it thereI have put fast eddy 10x15x4 bearings on my slipperclutch and sungears i have a also installed 8 12x18x4 bearings on my drivetrain but i think im going to change them they are rubber sealed one side but its not correctly sealed there is a gap between the seal and the cendpter of the bearing i thought they were both side sealed but there was a misleading picture on the amainhobbies websiteView attachment 48642
View attachment 48643 onne seized completly
I have rear lights under my wing:3 they look really nice
Front of the body was rainforced with two layers of dry wall tape and a lot of shooe gooe i started having cracks after a lot of nose landings this bosh is so thick and durable and i can get a new one for 40$ canadian dollars so much better than my old rc who was 80$ for a weak body
While i tried to rebuild my rear shock one was so tight and i snapped the rod end off.. im trying to epoxy it back togueter with metal wires to prevent it break again the remplacement shafts/rpd ends are 18$ a costly mistake from meView attachment 48647
Im waiting for my alluminum pivot balls because my steering radius is reduced because of the worn pivot balls? I hope i receive them before friday because its almost 2 weeks im waiting
Blue locktite did nithing for my slipper since i red locktited it never had an issue sinceNice truck. I have one too. Had the same shock snap and had to buy new spring perch. Diffs too. My slipper came loose several times. Blue loctite helps. I do 1 and 1/4 turns from tight and it seems to work. In the beginning I had it completley tight and stripped my diffs. Now I set it loose but it's hard to keep it there
Its normal its going to break in after a few runsI can't get my new ring and pinion to spin freely. Tried new yokes, shims on one side, shims on the other side, tight screws on yokes, loose screws on yokes, just won't spin freely. Keeps catching in one spot
K I'm just gonna put the shim where it says to put it in the manual and hope for the best.Its normal its going to break in after a few runs
If you put the shim to the other side but idk anymore maybe theres a reason they put the shim to the crown gear side
I’ve got a cart loaded right now but can’t pull the trigger. I haven’t even ran my Typhon 6s rig yet and I’m already thinking of stretching it. ????Menaged to get my loterry ticket and ordered a fair of front shocks from the typhon 6s and a pair of outcast fromt shocks who are the same as the typhon shocks of the rear but with differant springs. At the same time i bought the
The wing module of the 4s with bumpers the wing alone is 15$ new. For 8$ got wing itself wing mounts and other stuff who belong to the rear. One of my wing mounts is cracked and my wing is worn because me driving like a nob and doing roof speedruns on concrete
All from jennyrc
What your planning to buy?
:0
I really only need the one longer center shaft. I might just get the SupaHD ones instead anyways. ??:0
Bruh my plastic driveshafts are more expensive than your steel ones lol
