Curious to know what some of you speed runners are setting your toe ..what seems to be your go to settings to get your car straight?
+1 I rather keep my toes!I try to keep the car away from my toes![]()
Not true. You can adjust the front.You can only adjust the rear camber
Correct. Not sure what I was thinking.Not true. You can adjust the front.
This further leads me to believe that you're confusing toe-in with camber as toe-in has no effect on the contact patch of the tire.Ok so how I've been doing it is with full load .meaning lipo is in and I turn the transmitter on then receiver (obvious) then on the front wheels I put them at 0 negative .so now I should turn them in a few mm.the bottom of the wheels are flat covering all surface pad.so by turning them in a few mm or 1/16 what will that do? Is that for a straighter pass?
From the pics (take it for what it's worth) it look like a bit of toe out an positive camber. If you want 0 camber you can use a speed square. It's probably one of the easier adjustments.They are at negative 0 .so now I'll turn them in by a few mm .and then I'll do a few speed passes and see what the difference is . hopefully it makes it better.im limited to this stock spectrum transmitter.i might use my FS -GT5 . I only use it for my RC boats but since I can program up to 10 models on it I'll add this one to it also.probably get better range to.
The reason for showing the transmitter that I'd like to use is that it has a better option to adjust my stearing much more than the stock big rock transmitter.all I have on the stock is a dial .left and right and neutral..not really accurate..on the other one I can dial it in better I believe maybey it will help .that's what I'm thinking.i did show a pic of both wheels.maybey the pics ain't all that great but I set the wheels as straight as I could .I used a t square like mentioned to use and I don't know what else to do .Question from the back
What does negative zero mean? Zero is neither negative nor positive. It's just zero.
I don't understand what your transmitter or its limitations has to do with the toe-in of your vehicle. Could you elaborate?
From this picture I get the sense that you're showing us the camber of your front wheels as it's not possible to see toe-in when a single wheel is viewed from the front. You can only really see it in context with the wheel on the other side when viewed from above. More on this below.
I think part of the problem is that this picture here muddied the waters and you may have thought it was a head on picture of the wheels. It isn't. It's a view from above.
Toe-in is the measure of how "pigeon toed" your car is. If you look at the rear wheels of your Big Rock from above, you'll notice that the part of the tire facing forward is pointed towards the center of your car whereas the rear facing part of the tire is pointing outward. This is called toe-in.
Here's an illustration to help clarify. The red arrows are pointing to the rear wheels which have 2-3° of toe-in. The blue arrows are pointing to the front wheels which, if I had to guess, have 1.5-2° of toe-out.
Let's focus on the rear wheels for a moment. What toe-in does is increase straight line stability as it drives the wheels towards the centerline of the vehicle as illustrated below.
So what does toe-in/toe-out do when it comes to the front wheels? If you're running a little bit of toe-in on the front, this will increase straight line stability at the cost of steering response. If you're running a bit of toe-out on the front, you sacrifice straight line stability for a higher steering response.
To explain this a little further, if you imagine the front with toe-in (both wheels pointed inwards), it requires you to steer further to the left or right before both wheels are pointed in the direction you want to go. If, on the other hand, they're already pointed outward slightly (toe-out), one of your wheels is already pointed in the direction you want to turn in making it more responsive. I hope this makes sense.
As to the question of camber (tires leaning in or out from a front/rear view), this is really only relevant to a car's ability to turn corners and of no consequence to speed running. All it does is give you uneven tire wear since you would always be riding on the inside edge of your tire if you were to run negative camber (and on the outside edge if you were running positive camber).
Hope this helps.
